large information window
UG 7.5, part modeling
whenever I change something a large information window pops on the screen. It was not that but I made some change and now cannot remove it.
How I can remove information window...
RE: large information window
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
When I change dimension in sketch and press enter, it comes on the screen.
When want mass of the part it comes on the screen showing mass and many other things...
As for the window showing up after you make a change to a sketch dimension, I'd guess this is an update report. You can turn it off (part specific) in Preferences -> modeling -> update -> generate warning/failure report after update. You can also turn this off in your template part(s) (if you use them) and/or the customer defaults to affect new files created.
www.nxjournaling.com
Thank you a lot
