Changing Sketched View
I have my sketch in top plane. I wanted the sketch in front plane. How to change it. I am using nx 7.5.
Thank You.
RE: Changing Sketched View
Right Click on sketch - Edit with Rollback ( This will take you into sketch environment)
Then Tools - Reattach and you need to select on which plane and orientation Axis you want to reattach your sketch.
This will serve purpose.
Thank You
