Lowering terminal velocity by increasing air density
Hello experts!
This is my first post and it's an 'ask someone with a lot more aerodynamics knowledge than me' kind of post, so forgive me if it needs to be posted elsewhere.
This has been bugging me for some time, explained as follows. I will use point form so that my assumptions / knowledge can be easily snared and corrected:
A question in two parts:
Image 2
The main reason I ask is that I am wondering whether it is possible for some sort of 'structural parachute' that would work at any altitude and significantly reduce a falling person's terminal velocity. I am predicting that it is possible but it will fall into the 'asking too much from physics' basket - which would explain why I haven't read about it elsewhere
Thanks for your time and your thoughts!
- Terminal velocity
- Terminal velocity depends, partially, on air density, i.e. if the atmosphere is denser on planet X, for example, then the same object falling on planet X would have a lower terminal velocity than on Earth
- Airfoils
- A basic airfoil is designed to create a pressure differential
- On one edge of the airfoil there will be a greater air pressure as it is accelerating
- Visualise, then, an airfoil that was shaped into a 'ring' instead of a flat 'wing' (see attached files)
- If this 'ring' was falling vertically, and designed with the cross section of such an airfoil, could a greater air pressure be induced inside this ring?
- If so, would there be a way that this increased air pressure could be harnessed such that the terminal velocity of the falling body could be significantly reduced?
- The effectiveness of such a device would be lower at lower accelerations / velocities. If our falling 'ring' reached terminal velocity - i.e. when acceleration stops, would there be no more pressure differential?
- Would the overall effectiveness of the 'ring' be less at thinner atmospheres?
- Could the (higher pressure) air be funneled into a parachute / drag inducing mechanism in order to lower the terminal velocity?
- Is this re-inventing the wheel i.e. does something like this already exist? I am curious.
Image 2
RE: Lowering terminal velocity by increasing air density
Notice the function of the ring and how it functions in the lines of the parachute. When the aircraft is at high velocity, the ring closes the parachute to prevent structural (fabric) failure. As the aircraft slows down the ring slips down the lines and that allows the parachute to open fully.
Bronc
Bronc
Bronc
If so, then you are smarter than the knuckleheads at NASA, who resorted to huge inflatable air bag to land the Mars rovers safely.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
a random thought d'jour ... a rotating streamer would increase the work done by the wake, ie increase the drag, and might be more stable ...
Sorry. I didn't mean any disrespect. I just figured it might be one of those space elevator kind of problems e.g. "you could do X but you'd need a tensile strength of Y which means you'd need a material a thousand times stronger than Z".
i doubt the idea has that much merit. what you're looking for is a high drag profile
Everything I've read about it so far makes me agree with you 100%. If indeed the higher air pressure could be induced, however, surely there could be some way of making it 'work' to create additional drag?
The concept of some kind of tilt-rotor (?) or some mechanism inside the ring occurred to me that it could possibly get the air to do that 'work', but as I understand it, tilt-rotors generate down-force from the above air which wouldn't apply in this scenario.
Again, thanks for the feedback!
The result is what you see today on the Cirrus.
B.E.
You are judged not by what you know, but by what you can do.
