Modifying the classic Push Puppet?
Saw this video about how to build a Push Puppet (Link)
Is there a way to duplicate this mechanism using a stronger material other than string?
RE: Modifying the classic Push Puppet?
200lb tensile strength and it costs about $0.20/ft.
Monofilament is strong, but it's hard to tie it into a knot that won't loosen immediately.
Aramid is worse than monofilament; it splinters (watch your eyes!) when bent to a tight radius, like in a knot, and the metal crimp rings sold for terminating it won't hold, even when used with the recommended special crimping tool.
I'm guessing that you might be able to terminate aramid into a reverse tapered fitting filled with epoxy, sort of like you terminate wire rope with molten zinc. You will probably need more patience than I can muster.
Mike Halloran
Pembroke Pines, FL, USA
It would help to have more details about the application. Some type of heavy polyester or nylon thread might be satisfactory, versus a piece of common cotton string.
Is there a way to re-create this type of collapsing mechanism using plastic?
The reason I want to duplicate the Push Puppet mechanism is because it's more applicable to the apparatus i'm working on than the typical lock/release spring loaded mechanism because of physical obstructions that are present with the apparatus
While it might be possible to use a plastic tension element for your mechanism, you need to provide more specific details before I can say for sure what might work.
You'll need to explain more clearly why fishing line or string are unsuitable. What failure mode to they have that you want to avoid?
A braided yarn or thread works for this application because it is very flexible when unloaded. But something like 100lb test mono-filament fishing line might be too stiff to permit the flexing of the joints desired when unloaded.
Anyway, the reason a typical spring-loaded lock and release button will not work is because the objects that need to be collapsed will be rotating horizontally 360 degrees around a vertical tubing unit. There can be no obstruction within the vertical tubing unit and positioning a collapsing mechanism on the outside of the vertical tube will obstruct with the rotating units. Also the collapsing mechanism has to take in account that the location of the horizontal rotating units will vary, so the collapsing mechanism must be available around the entire vertical tube.
With that in mind, the only option I see is creating a separate tubing container for the collapsing mechanism that is positioned in between the vertical tubing and the rotating horizontal units
What do you guys think?
Thanks to anyone that has contributed so far, your input is appreciated
... is a proven recipe for failure.
... especially, given that you can't reveal the nature and specifics of the 'different apparatus'. We can't help you build a better automobile if all you can talk about is a boat.
Instead, you have to evaluate the needs of the 'different apparatus' in its own context, and solve the problems you can foresee within that context.
Mike Halloran
The OP did not say "no" When TBuelna said "I can see a situation where an arrangement of rigid links (like a chain) that have swivel joints at each end that align with the skeleton joint centers when tensioned could possibly be made to work. " .
The style of indicator mount in the picture I provided would function as I
understoodimagined it described, right up until OP most recently said " the only option I see is creating a separate tubing container for the collapsing mechanism that is positioned in between the vertical tubing and the rotating horizontal units." That left me with an empty thought balloon.Without the picture you asked for my balloon will likely remain empty.
Since TD24 has not logged on for a couple of days, and all his log-ons were over the past weekend, perhaps he has moved on.
regards,
Dan T
