New Modern Steel Article on Specifying Material
The February 2015 edition of Modern Steel has a new version of "Are You Properly Specifying Material" Some interesting changes such as ASTM A500 grade C is the preferred specification for HSS (it was grade B). It is worth a peek: http://msc.aisc.org/globalassets/modern-steel/arch...
RE: New Modern Steel Article on Specifying Material
Will there be an AISC Errata to cover this?
