Coating for acidic environment
We are designing a grating system that requires acid resistance. We are using fiberglass grating, but I am wondering about the steel framing. Is there some sort of standard coating commonly used for acid corrosion resistance?
- Aaron
- Aaron
RE: Coating for acidic environment
There are companies, such as Strongwell, who make FRP structural shapes. They'll even design them for you, if you specify it that way. I don't like delegating designs like that and using exotic materials, but they do a good job.
