White Cast Iron Conversion Charts for Leeb Type "D" to HBW/HRC?
I've been trying to find data for approximate conversions between Leeb Hardness Numbers (Type D Device) and an indentation hardness method/scale (HBW, HRC, HV, etc), for high chromium white cast irons (e.g. BS4844 Grade 3D) specifically. Has anyone come across data comparing these HLD to one of the indentation scales for these alloys?
RE: White Cast Iron Conversion Charts for Leeb Type "D" to HBW/HRC?
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
I would be very leery of using rebound hardness for a material that is as non-homogenous as a white iron.
