Assembly will not update !!!!!
Hi, I am new to proe. I have created an assembly using bottom up method. When I make a change to the sketched file the part and the assembly do not reflect the changes. Is there something that I need to do to cause this to happen, or should proe do it automatically?
Thank You,
Chris H.
Thank You,
Chris H.
RE: Assembly will not update !!!!!
Once you change the section in part file, automatically Pro/E updates that part in assembly.
Hope this is what you expected.
Cheers...
Yogesh Birari
