Mercury contaminated crude & Corrosion in Refinery
Any experiences regarding mercury contaminated crude oil processing from corrosion point of view?
Is there any mercury limit in crude to avoid overhead fractionator trays (made of Alloy 400) LME corrosion by mercury?
What is the best metalurgy solution for HCl overhead corosion and mercury induced LME corrosion on CDU?
Is CS susceptible to LME under some conditions?
RE: Mercury contaminated crude & Corrosion in Refinery
from the wikipedia article on amalgamation: "Almost all metals can form amalgams with mercury, the notable exception being iron."
http://www.ipieca.org/publication/mercury-manageme...
The attachment also has some helpful information. The important first step is to characterise the form of the mercury in the process fluid.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
In the one process stream (lighter one) Hg level is cca 80 ppb (acording Randman analysis) and I am afraid that that level is to high.
