Determine force on bracing beam?
A heavily loaded 30ft beam that needs a brace midspan to oppose LTB buckling. If this beam is only loaded vertically, how do I determine the required strength of the bracing beam needed for LTB buckling resistance?
RE: Determine force on bracing beam?
Look through that and read the commentary on it and you should have your questions answered.
You can make a numerical model, load it, read the deflections. Make a new model of the bracing beam, feed it with the given deflections (forced deflections), or make a force using Force=stiffens×deflection...
Live long and prosper!
