NX 7.5 Journaling - Moving all Flat Pattern entities in to a layer
Hi All,
We have a requirement to move all flatpattern objects in to layer 151. This task need to be done for several part files.
I have created below journal to do this task. we need to open each part file and run this journal.
This code find outs all custome views and filters the views with "FLAT-PATTERN". After that it switches to each flat pattern view and moves the visible objects to layer 151. If the part file is not having flat pattern view it gives a message on the scrren.
This journal is moving all curves in to layer but excluding flat pattern annotations(labels).
Can someone help me in improving below code. Thank you in advance.
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim theUI As UI = UI.GetUI()
Dim workPart As Part = theSession.Parts.Work
Dim dispPart As Part = theSession.Parts.Display
Dim basepart As part = theSession.Parts.Work
Dim Vwlst As Array
Vwlst = Basepart.Views.GetCustomViews()
Dim b As Integer
b=0
Dim c As Integer
c=Vwlst.Length-1
Dim fviews As Integer
fviews = 0
If Vwlst.Length > 0 Then
For b=0 to c
Dim vn as String
vn=Vwlst(b).ToString()
Dim ff As String
ff=Left(vn,12)
If ff = "FLAT-PATTERN" Then
fviews = fviews+1
Dim layout1 As Layout = CType(workPart.Layouts.FindObject("L1"), Layout)
Dim modelingView1 As ModelingView = CType(workPart.ModelingViews.FindObject(vn), ModelingView)
layout1.ReplaceView(workPart.ModelingViews.WorkView, modelingView1, True)
workPart.ModelingViews.WorkView.Fit()
Dim wv As View
wv = Basepart.views.Workview
Dim ViewObj As Array
ViewObj = wv.AskVisibleObjects()
workPart.Layers.MoveDisplayableObjects(151, ViewObj)
msgBox("Moved all visible objects to layer 151 in view "&vn, ,"Flat Pattern Layer Move")
'lw.writeline("Cusom view name is = " &vn)
end if
Next b
If fviews = 0 then
msgbox("There is no flat pattern view", ,"Flat Pattern Layer Move")
end if
Else
MsgBox("There are no custom views", ,"Flat Pattern Layer Move")
end if
'Dim wv As tag
'wv = Basepart.views.Workview.tag
'lw.writeline(wv.ToString())
End Sub
End Module
RE: NX 7.5 Journaling - Moving all Flat Pattern entities in to a layer
Try the following code; it iterates through the current work part's features looking for flat pattern features. When one is found it gets the curves and annotations and moves them to layer 151.
CODE
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Module1
    Sub Main()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "move flat pattern objects"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Const flatPatternLayer As Integer = 151
        Dim flatPatternObjects As New List(Of DisplayableObject)
        For Each tempFeature As Features.Feature In workPart.Features
            If TypeOf (tempFeature) Is Features.FlatPattern Then
                Dim theFlatPattern As Features.FlatPattern = tempFeature
                Dim fpCurves() As NXObject = theFlatPattern.GetCurves
                For Each tempObj As DisplayableObject In fpCurves
                    flatPatternObjects.Add(tempObj)
                Next
                Dim fpAnnotations() As NXObject = theFlatPattern.GetAnnotations
                For Each tempObj As DisplayableObject In fpAnnotations
                Next
            End If
        Next
        Dim displayModification1 As DisplayModification
        displayModification1 = theSession.DisplayManager.NewDisplayModification()
        displayModification1.NewLayer = flatPatternLayer
        displayModification1.Apply(flatPatternObjects.ToArray)
        displayModification1.Dispose()
        lw.Close()
    End Sub
End Module
www.nxjournaling.com
Excellent cowski, This code is working exactly what we need. Thank you very much.
