Nc assist gas regulator
Does anyone know if these valves can be rebuilt, and where I could get parts and instructions? The machine is a Amada Lasmac LC-1212 alpha 11. The present reg was installed about 4 months ago new and now we find out that it only has a 90 day waranty. Any info or pics of the inside would be appreciated.
Thanks for your time
RE: Nc assist gas regulator
The long and short of it is that there is not a rebuild kit for either NC regulator, that I know of. I could be wrong but I just haven't seen anything.
If you want, tell us a little more about what your machine is doing or not doing and how you are asking it to do it. We will see if there may be another solution to the problem.
has never had a manual control for the gas, if you dont count ajusting the pressure from the supply tanks with that
gas reg.
The name on the regulator is Asahi Hyper Regulator # 752EHA
This reg is leaking gas from an outlet port, since its off warrenty we opened it and found a small tear in the diafram
which is why its leaking. I find it difficult to beleave that a $3000.00 part that comes apart would not have a kit or a way of getting parts. So thats why I asked here, I thought mabe someone run into this before and fixed it.
Thank you for answering I was wondering if anyone had read it.
