GRAYLOC ENLARGING AND REDUCING HUB CONNECTORS-DIMENSIONAL DATA
Hi everyone,
I'm a Piping and Layout Engineer currently working on design of an offshore Riser with the intent on using Grayloc hub connectors. I have gone through the Grayloc products online and given all information concerning the standard hub connectors but couldn't find any information regarding Enlarging and Reducing hub connectors. Can anyone help with this?
RE: GRAYLOC ENLARGING AND REDUCING HUB CONNECTORS-DIMENSIONAL DATA
If they don't know then no one else will....
It's not clear though to me what you're trying to do though - "Enlarging and Reducing hub connectors". Are you trying to use bigger ones or what? If you define your question a bit more or add a sketch, then you might get some answers, but look at it afresh and see whether what you wrote actually gives anyone enough information to assist??
http://www.google.com.au/url?sa=t&rct=j&q=...
Sorry for the not-so-immediate reply to your 'reply' but I've been quite tied-up with work. Yes, I guess I didn't leave enough information to receive 'enough' help; I am dealing with a 6-inch riser and terminating in a grayloc hub diameter of 8" so I do have a case of using a 'Enlarging or Reducing' hub connector. I couldn't get the detail for this item . However, I finally got a response from the manufacturer, i.e. Grayloc and things sorted out. Your responses are well appreciated. Thanks.
Saplanti
I've already been through the catalogue. Thanks anyway.
