UserFrom Selection and Reload
Hello evrybody,
I have two problem with my macro :
1)I load a USerForm no modal and I ask the user to select different kind of item with SelectElement2 but when then UserFrom appears I can select anything in the product tree. My macro is launched from Excel my be the problem come from here but I have to.
2)On my UserForm I have a reload button but when I click on it I have an error message "It is illegal to call out while inside message filter" may be cause when I click I am at this line
Status = selection1.SelectElement2(InputObjectType, "Selectionner nouveau point d'origine", False)
If you have any idees thanks
RE: UserFrom Selection and Reload
I found a solution using SelectElement3 and do not reset my usrform but only my captation.
