is aci 10.6.4 crack control always applicable?
should all reinforcement for beams and footings and slabs be checked against aci 10.6.4 crack control ?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: is aci 10.6.4 crack control always applicable?
Personally, I have never fully bought into this section of the code. If you're really concerned about cracking and corrosion and such, you might take a look at ACI 350 which has different provisions covering the same basic topic.
Unfortunately, we have a new foundation software and it's giving warning that crack control spacing is not met.
I'm now trying to justify how to get away from this warning. Is there any documentation to justify not using this?
Maine Professional and Structural Engineer.
(Just passed the 16-hour SE exam, woohoo!)
The software probably assumes 2/3 fy which is permitted by the code. But, you could probably do some hand calculations to justify a lower value. And, therefore a larger maximum spacing.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
