global variable in MATHCAD 15 and Prime 3.0
Hello All,
How can we explain that when we evaluate a global variable between two global définition with the same name, the value is identical to the first one and not the last one in the worksheet.
I use Mathcad 15 M30.
For the same example, with prime 3.0, Mathcad returns me that we can't define two global defintion with the same name. Which is the message that we expect for.
Thanks in advance for the response.
Sidi
RE: global variable in MATHCAD 15 and Prime 3.0
Think of Mathcad as a scripting language that executes like any other programming language, i.e., evaluations occur left to right and top to bottom, just like C or Matlab. Every time you recalculate the sheet, the script runs through its paces.
The <SHFT>~ is a "global" variable assignment, ONLY in the context of its "scope" in M15; in programming, scope refers to the regions of the program where a variable or constant is valid.
If a single instance of z <SHFT>~ 5 exists, then the scope of z=5 is everywhere in the sheet, but a second instance, say z <SHFT>~ 3 is instantiated, then the scope z=5 is only between the the two <SHFT>~, while the scope of the second <SHFT>~ exists everywhere else.
So,
r := z+1 = 3
z <SHFT>~ 5
r := z+1 = 6
z <SHFT>~ 2
r := z+1 = 3
In Mathcad Prime, that paradigm was changed, since the M15 paradigm is a little bit inconsistent, because the left to right, top to bottom, evaluation order is actually violated for the <SHFT>~ assignments, since they're basically assigned and calculated before the rest of the sheet, which should have resulted in z=2 all the time in the example above. If that was the intended paradigm, then multiple <SHFT>~ assignments of z should always take the last assigned value of 2, and there should be no instance of z=3 anywhere in the sheet.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Thanks a lot for those pedagogical explanations.
Best regards,
Sidi
