Fastener load estimation from global FEM
I have a global wing model, with plate elements for skin, ribs and spars and beam/bar elements for stringers and other longitudinal members.
which is the usual way for the estimation of the loads of a group of fasteners on a wing spar panel? should I use the nodal interface loads or estimate from the elemental stresses? how?
The panel is delimited between the vertical longeron stiffeners and the longitudinal ones.
