Upstream power transformer for a 400 KW VFD
hi all
In Order to supply a VFD system (400 KW) we should install a power transformer (60 KV / 5.5 KV).
my question is : is there special consideration about that transformer regarding to harmonics caused by the VFD ?
thanks.
thanks.
RE: Upstream power transformer for a 400 KW VFD
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Gunnar Englund
www.gke.org
