Steel Reinforcement Corrosion in Concrete
Hi All;
In some columns of my house the contractor has not cut off the excess reinforcement steel bars. They are sticking out of the column. I presume they will get rusted over time. My worry is; Could that rust penetrate inside the concrete? What should I do to prevent it from going inside? My house is located in a South Asian country where humidity could go up to 90% and temp 30-35 C.
Thanks in Advance
RE: Steel Reinforcement Corrosion in Concrete
You might be better off red flagging your own post and trying in the structural engineering other topics forum - a very busy forum.
Take some photos and any plans you have for the reinforcement and post them.
Are the columns exposed to the outside wind and rain?
Re-bar should not be "sticking out" unless it is there for future column extension.
The rebar sticking of the concrete out will corrode if not protected. Remove exposed rebar and grout seal.
If you are in a coastal environment, more problems should be expected.
