Where does New Mexico stand on the Industry exception for drawings / documents stamping
Any help on where the New Mexico Board of engineers stand for Industry Exception for drawings / Documents stamping would be appreciated.
A reference to their state laws on this matter would help.
thread765-366275: Texas brings down the hammer on the "Industrial Exemption"
RE: Where does New Mexico stand on the Industry exception for drawings / documents stamping
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
A few years ago the board put on seminars where board members would give talks and then answer questions (this qualified for the ethics PDH requirement). I didn't see one in 2014 so I took a very lame industry ethics course. When they did those seminars, that question came up every session. The last one I did was 2010 so their position could easily have changed, but back then, the big issue in Oil & Gas was SPCC plans. The NM board said they didn't think that SPCC plans qualified as "holding yourself out to the public as an engineer" and they said that they wouldn't be checking stamps on SPCC plans (the federal regulation requires a P.E. stamp). This discussion really brought out that the NM board (then) felt like their role is protecting the public, not companies. If you were doing the structural stuff on a building that people would be working in, then the drawings/calcs needed to be stamped, but if you are doing hydraulic calculations for vessel sizing there wasn't a public-safety component and they didn't care if it was stamped or not.
That was 5 years ago and the Texas nonsense has stirred up a bunch of new mud in the water. I'd check with the board.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
TTFN
16.39.3.12 SEAL OF LICENSEE:
A. Each licensed professional engineer shall obtain a seal/stamp, which must appear on all design drawings, and the certification page of all specifications and engineering reports prepared by the licensee in responsible charge.
However, this particular clause in the statute does not control the actions of unlicensed individuals nor does it address whether (the work in question) requires a licensed individual.
cvg - Read the definition of the "Practice of Engineering". It is tremendously broadly worded and almost every real engineer in any industry is "practicing engineering". Whether he/she needs a PE license from a state and depends on the listed exemptions to engineering practice as listed by that state's laws.
Ask the NM PE Board in Santa Fe.
