Anchor Heads
Anchor Heads
I'm a junior engineer, however through my calculations I found that the appendix D specifies pullout strength as the effective area of the bolt head times 8 times the compressive strength of the concrete. SO... then I noticed that square nuts provide more pullout strength than hex head nuts. Do you guys agree? And if you do, why aren't they typically used?
RE: Anchor Heads
We use welded steel washer plates, which are square, just because they're easier to cut that way.
RE: Anchor Heads
RE: Anchor Heads
RE: Anchor Heads
