Using the draft feature - SW 2015
RE: Using the draft feature - SW 2015
I got it figured out but not the way I wanted to do it. I would like to set an end limit to the draft of where it would meet the face but instead I just played with the angle until it got close enough. And the angle is 77.47degrees.... This will work, but anyone have any ideas for future applications? Thanks again.
http://files.engineering.com/getfile.aspx?folder=0...
Good to know. My apologies.
Let the start face drive the rest, if it needs to be exact. You can apply a positive or negative draft angle.
