DNV-OS-F101 Appendix C - F303
Dear All,
The 80MPa of difference that this paragraph asks between base material and weld material, are to be considered after mechanical test or data Nominal tensile?
Thank you in advance,
Emilio A.
Emilio A.
RE: DNV-OS-F101 Appendix C - F303
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
So is correct to consider that after tensile test the difference between weld material and the base material must be as minimum of 80MPa.
