Too many attempts made for this increment error message?!
Currently working on my dissertation for University and as a fairly inexperienced Abaqus user am having some problems. I am required to run a series of simulations on a jacket foundation structure (the support for an offshore wind turbine). I began by modelling the foundation as a solid model but found this was too complex and would not mesh correctly so have now made a much simpler wireframe model of the structure. A few things I am having problems with though;
1. The members are all hollow cylinders but when I assign section properties I only have the option of shelling which takes the thickness of the member into account but not the diameter which is surely of great importance? I ended up using the truss section and have used the outer diameter to find the cross sectional area so this I know isn't currently right.
2. The load applied is a uniform body force which should produce a uniform load across the entirety of one face but this could be causing me problems when I run the simulation.
3. I am getting the error message "Too many attempts made for this increment". I have looked at multiple forums and the same answer comes up as to change the increment values. This, I have tried many ties and it hasn't worked so I am sure it must be something else causing me problems.
4. Finally my BC's are the four leg ends (where piles would be) so I have put BC's here with only rotation allowed but again this could be wrong?
Any help would be greatly appreciated. Have now been mulling over this for a number of weeks and the deadlines approaching! Thanks for any help in advance and the model is attached if anyone wants to look over it. Regards,
Nathan
Nathan
RE: Too many attempts made for this increment error message?!
