Calculating Vapor Composition from known liquid composition
Need some help extracting this from my brain. I need to calculate the vapor composition of 60%isopropanol/water mixture at atmospheric pressure and 160 F (for scrubber emissions estimate). Tried running a flash in aspen but nothing flashes. I feel like this should be easy to calculate by hand but can't find a great example in my thermo book.
RE: Calculating Vapor Composition from known liquid composition
Good luck,
Latexman
Technically, the glass is always full - 1/2 air and 1/2 water.
You are on the right track. Then once you have the mole fraction multiply that by the air flow to get your emissions.
StoneCold
