Can I use mesh mating conditions when i already have a face contact constraint?
Hi, I want to improve my results for the contact force of a impeller-shaft assembly.
Therefore I want to align the nodes of the different part faces with the mesh mating condition (mmc).
Before I defined a surface-to-surface-contact. When I now set the mmmc I am not able to update my mesh.
I get an error message: Frozen data error during volume meshing
Does anybody know what I did wrong???
RE: Can I use mesh mating conditions when i already have a face contact constraint?
I believe the mmc and surface contact definition are conflicting each other..
