Electronic circuit design
Hello engineers,
my pleasure to be here in that professional engineering Forum, and seeking help from electronics Experts
well, i am working on circuit design for the first time, relying on my little experience into electronics, and especially Electronic circuit design
the circuit, takes audio signals at a frequencies of " 1 or 10 or 100 and up to 1khz", in damping waveforms, and the circuit purpose is to output pulse current doesn't exceed 100 micro-ampere, and voltage ranges from 20-450v, and pulse frequency from 4- 351 hz
my question, what is the right direction i go through the design of such a circuit, for example, Filtering the input signal, amplifying, then convert to pulses using PWM ic, then output through transformer or other way?, if this is a right direction, how i convert from damping waveform to pulses?
any suggestion for a block diagram to use in that design?
Btw: the circuit is powered by 1.2v, 2100mah AA battery, and there are two buttons up/down to control the output voltage
i just need your suggestion for a block diagram, or right direction to follow for the design, and if my direction is fine what's the name of the circuit i use to convert from audio signal to DCv pulses?
Will appreciate your reply
RE: Electronic circuit design
Dan - Owner
http://www.Hi-TecDesigns.com
"damping waveforms" - what do you want the pulses to represent? Amplitude? Frequency? When you process the pulses elsewhere in the system, what information are you attempting to 'receive'?
"20-450V"? Did you mean millivolts (0.020-0.450V)?
Zapped, the pulses will be represented at that voltage range, of 20-450 v, at a current up to 100 micro-ampere, and no they are not milli-volts, they are pulse volts " Square wave", at very low current and their frequency will be between 4-350hz
and all this, is from audio signal, coming from cell phone " Android phone", something like the audio file you playing at your cell phone, but instead of hearing the song or that audio file at your headphone, it get connected to that device i am working in its design
and this audio file frequency can be 1 or 10, or 100, or up to 1khz as I've mentioned before
The information i am attempting to get Zapped, is that if you are working on this design, how you would get from audio file a controlled pulsed current and voltage?, and what are the steps you would follow to design it?
Mac, helped me a bit with his response, and i am quite deciding this block diagram, take a look, and let me know if suggest better block diagram, or if i miss something
There are so many unclear things in your specification, one is "audio signal, coming from cell phone " Android phone", something like the audio file you playing at your cell phone". Does that mean that you think that the audio file is analogue data? Or are you aware of the different coding systems used for audio files?
You are also mentioning that your input signal contains 1 and 10 Hz. It does not. There is a lower band-width limit that definitely is above 10 Hz. So that will be a huge problem.
Is "damping waveforms" important? And what does it mean? Decaying ringing?
I think it would be a lot better if you describe what you want to do instead of telling us how you are going to do it. After all, we are the guys that "know how to" and you are the guy knowing the "want to".
Gunnar Englund
www.gke.org
Go to :
http://www.ti.com.cn/cn/lit/ds/symlink/lm2907.pdf
Use the :
LM2907, LM2917
FREQUENCY-TO-VOLTAGE CONVERTERS
For the high output voltage use a close loop Amp with HV Mosfets the output of the F/V shall be the reference
The supply voltage is low you may need a Step up DC/DC converter
Good luck-daveross100atgmaildatcom
