macro from nx7.5 to nx9
This macro doesn't work in the same way.
In NX 7.5 after change the option in "change window"
to "contain the characters you type" and set immediately after each..."
came back to "change window" with the cursor ready in field of search text.
So when i run the macro (with a short cut) I can immediately type the part that I want.
Now in the NX 9 the cursor is not in the field
so i must click inside the field.
I have try to build the macro natively from NX9 but with the same result.
NX 7.5
www.studiotreccani.com
