Renaming part file
Renaming part file
Renaming part file
I wanted to rename my part file(Ex: Bolt.prt to Cap.prt) in nx 7.5. Please help me in this regard.
Thank You.
RE: Renaming part file
There's no problem renaming a part file, up to a point. However, if this part is used as a Component in any Assembly those Assemblies will not know that the file name has changed and so they will no longer be linked to the renamed file. If this is your situation, after you rename the part you'll need to open each one the Assemblies and do a replace Component replacing the now 'lost' component with the newly renamed Component and then resave the Assemby.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Wouldn't it be easier to just open all the assemblies (depending on the amount, of course) where the part is used, then do a save-as (which will replace the component in all opened assemblies) and then discard the old one?
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
That would work as well.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
how to replace part in assembly?
Open the Assembly, select the Component of interest, press MB3 and select the 'Replace Component...' item.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank You
