jenbacher 420 engine room cooling
Jenbacher engine 420 run low power than normal in the summer time. Think about cooling system such as coolbreeze cooling system. But one of The problem coolbreeze cooling effect intercooler inside tim - placed plate. Humudity Of cooling air react H2S in intercooler too much. Who is used that cooling system for jenbacher engine ?
RE: jenbacher 420 engine room cooling
That would be my recommendation if you want to modify or upgrade your installation.
"Schiefgehen will, was schiefgehen kann" - das Murphygesetz
