Export DWG 1:1 scale NX 8.5
Is it possible to export a NX drawing to DWG in Scale 1:1?
I can only get the dwg in the scale that the views in the NX drawing are created.
This is a big problem because the measurements taken in the DWG are incorrect because the views are not in 1:1 scale.
Example: if Views are created in NX with Scale 1:10 then if I measure in AutoCAD the measurement is 10 times smaller than it should be.
Or are there any other solution to my problem?
I know that I could change the scale in NX or AutoCAD to 1:1, but this is not an option.
Using NX 8.5 and Teamcenter 9.
RE: Export DWG 1:1 scale NX 8.5
That's unfortunate because I'm pretty sure that changing the scale in NX or AutoCAD is the only real option to get what you want.
In the thread linked below, you will find a journal that automates the process to export dxf files at full scale. If dxf files are acceptable, perhaps you can use this journal "as-is". If you must have dwg files, then perhaps you can use the principles from this journal.
thread561-373765: Exporting drawing to dxf not to scale
www.nxjournaling.com
It’s necessary to have an option in NX to select “the output scale” in the export/save as window.
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V9.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Hopefully we will see an option where you can set the scale in the DWG/DXF wizard soon.
You prefer to model at other than full scale?
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
Drawing view creation gives the option to scale views. We are avoiding (because it's useless) that capability because Wire-EDM guys are using DXF files of 2D views. That is why other software offer DXF Output scale option.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Nevermind... a DWG/DXF scale option would be a useful enhancement.
-Dalai Lama XIV
