Heat transfer to/from burried oil pipleline
Hello
Please, your help:
I have real problem of heat tranfer of oil line, I have to solve:
Gasoline flows through a steel pipe line that is burried in the ground. I need to know the exit temp of gasoline in the exit from the pipe.
I know:
Properties of Gasoline
Cp = 2.22 Kj/Kg K
Density = 740 kg/m3
k : 0.15 W/mK
Viscosity= 0.88 cSt (0.88X 10-6 m2/sec)
µ = 6.512·10-4 kg/m s
Flowrate = 500 m3/hour=100 kg/sec
V (velocity)=0.76 m/Sec
T inlet of the Gasoline to the pipe = 13 deg C
T of ground= 16 deg C
Pipe properties:
Material : Carbon Steel
Outside Diameter: 20 inch= 0.508 m
Inside Diameter: 19 inch=0.4826 m
k=54 W/mK
Density=7833 kg/m3 (of the carbon steel)
Length of pipeline=2730 meter
How do I solve this?
1) Find Pr number for gasoline:
Pr=µ Cp/k
Pr=(6.512·10-4·2220/0.15)=9.63
Re= (0.76 ·0.4826/0.88·10-6)=416,790
Nu=0.029 Re0.8 Pr 0.43=2406
Nu=h·D/k
h=Nu k/D = 2400 ·0.15 /0.4826 = 750 W/m2K ( is that for the Gasoline only?)
Now, I think I have to use the follwing, but I am not sure how:
U=(1/hi+ ri/k ln(ro/ri)+(ri/ro·1/ho)-1
How do I calculate the the conduction of the ground/soil ? (lets assume that k= 0.5 W/mK for the soil)
Is the method diffrent if the soil(ground) is hotter or colder than the inlet temp of Gasoline?
Please help me find the outlet temp of Gasoline...
Thanks alot
Roy
Please, your help:
I know:
Cp = 2.22 Kj/Kg K
Density = 740 kg/m3
k : 0.15 W/mK
Pipe properties:
k=54 W/mK
Pr=µ Cp/k
Nu=h·D/k
Thanks alot
Roy
RE: Heat transfer to/from burried oil pipleline
If the gasoline is warmer than the soil, then the gasoline will probably cool down in the pipe, right. If colder than the soil, it will warm up. That's pretty elementary physics logic. Pr / Re / Nu / h calculates the heat transfer from the gasoline in the film next to the pipe wall. You will add that to the heat transfer coefficient of any other materials involved in the transfer; the pipe wall, insulation if any and soil.
In any case you are using the customary method. EXCEPT you don't calculate the ground's thermal coefficient of conduction. You must measure that in the field. Thermal conductivity of soil can vary from 0.15W/m-K, for an extremely dry sand, to nearly 1.8 for a water saturated soil. As you might guess, some digging is in order. The effective conductivity of the soil will also vary with burial depth of the pipeline; see "shape factor".
Keep on studying, but for now pick a number (13 OR 16C) according to whatever temperature you need to use to make your next and ultimate answer conservative. I doubt you need or can calculate anything better, especially until you know the thermal conductivity of the soil.
Here's what you need to look at,
TM 5-852-5/AFR 88-19 Volume 5
Chapter 12
http://armypubs.army.mil/eng/DR_pubs/dr_a/pdf/tm5_...
Any questions?
If the inlet temp was 160C, then the answer could easily be "Yes". In that case I always start by calculating the thermal entry length (i.e., the distance required to reduce the dT by 80%). If the thermal entry length is less than the length of the pipe, then I use the ground temp for the outlet. If it is greater than the length of the pipe and it is in a region that matters, then your only choice is a thermodynamic simulator and some very detailed soil samples. The sand/soil numbers that BigInch quoted are for dry materials, a bit of moisture changes them dramatically.
This is absolutely a case where you need to determine if the answer will drive you to a different design. If not, don't worry about it. If so, then apply the appropriate level of engineering.
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
