SHS to LGS Triss Connection
Hello everybody!))
)) I will be very thankful if somebody helps, the main scheme is attached at the post.
As you can see My light gauge steel(Thin walled) truss is fixed to the Square hollow section
At 1 Square Hollow Section and LGS truss connection I use 2 angles near edges and fix them with screws or bolts..
My scheme is correctly selected for this situation?
I choose 4 pin supports as you can see in the scan, maybe slide supports needed somewhere? What do you think?
Thank you
