UF_LAYER_ask_work_layer
What is the equivalent vb.net function to get the current working layer?
RE: UF_LAYER_ask_work_layer
Hi Cowski,
Thank you. Still not there. I am now able to get all the objects on the working layer. But, there is still more geometry and objects than I need. Now, I want only the displayed objects on the screen and hence the current working layer.
Here's what I have so far.
Dim workLayer As Integer
workLayer = workpart.Layers.WorkLayer
Dim workLayerObjs() As NXObject
workLayerObjs = workpart.Layers.GetAllObjectsOnLayer(workLayer)
Perhaps:
{reference to part}.Views.WorkView.AskVisibleObjects()
www.nxjournaling.com
I've tried that too. workpart.Views.WorkView.AskVisibleObjects(). It is giving only the lines that are visible within the current screen display. If I zoom out I get more lines if I zoom in I get less lines.
Well, that makes sense...
CODE
{reference to part}.Views.WorkView.Fit()
Yes. I was afraid of that. I have the user clicking on lines and arcs. Don't want the view window to zoom out and then zoom back in. This is more tricky than I had previously thought.....just the way coding goes sometimes.
Are you only looking for lines and arcs? If so, it would be fairly easy to iterate through them, checking on the layer and hidden status to see if they are visible to the user.
