Copy the connectors
Copy the connectors
Copy the connectors
I created some connectors in a model but when I copy the mesh, are copied only the regions linked to connectors and not the connectors. Is there a way to copy the connectors?
Regards.
RE: Copy the connectors
If you are copying the mesh using the Entity selector then you could select regions and check the Select Related when you selection method to multiple.
Show the selection list to see which entities you've already selected.
Seif Eddine Naffoussi, Stress Engineer
www.Innovamech.com
33650 Martillac û France
Hi
I am trying to copy the mesh in the same modfem file to create a sandwich panel, so use the commands mesh -> copy -> element. I created the basic model and then I want to copy it in the x and y directions.
Regards.
