NX Journal - Move CSYS to layer, but skip CSYS on layer 2
I'm new to journaling and have a question I hope you can help me with. I found this code online, which moves CSYS to a specific layer:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.Features
Imports NXOpen.Utilities
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim ufs As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = theSession.ListingWindow
Const Layno As Integer = 41
For Each myFeature As Feature In workPart.Features
If TypeOf (myFeature) Is DatumCsys Then
'uncomment the following If block to skip internal features
'If myFeature.IsInternal Then
' Continue For
'End If
Dim csys_tag As Tag
Dim origin_tag As Tag
Dim daxes As Tag()
Dim dplanes As Tag()
ufs.Modl.AskDatumCsysComponents(myFeature.Tag, csys_tag, origin_tag, daxes, dplanes)
ufs.Obj.SetLayer(origin_tag, Layno)
ufs.Obj.SetLayer(csys_tag, Layno)
For Each thisObj As NXOpen.Tag In daxes
ufs.Obj.SetLayer(thisObj, Layno)
Next
For Each thisObj As NXOpen.Tag In dplanes
Next
End If
Next
End Sub
End Module
I would like to add something to this code so that it skips any CSYS that already was placed on layer two. Similar to what this script is doing with sketches:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
Const SketchLayer As Integer = 22
Dim i As Integer = 0
'move sketches
For Each sketchObj As Sketch In workPart.Sketches
'skip internal sketches
If sketchObj.IsInternal Then
Continue For
End If
'skip sketches on layer 2
If sketchObj.Layer = 2 Then
Continue For
End If
sketchObj.Activate(False)
sketchObj.Layer = SketchLayer + i
sketchObj.RedisplayObject()
sketchObj.Deactivate(False, Sketch.UpdateLevel.SketchOnly)
i += 1
Next
'Update layers by turning on and off layer 22
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Start")
theSession.SetUndoMarkName(markId1, "Layer Settings Dialog")
Dim stateArray1(0) As Layer.StateInfo
stateArray1(0).Layer = 22
stateArray1(0).State = Layer.State.Selectable
workPart.Layers.ChangeStates(stateArray1, False)
Dim stateArray2(0) As Layer.StateInfo
stateArray2(0).Layer = 22
stateArray2(0).State = Layer.State.Hidden
workPart.Layers.ChangeStates(stateArray2, False)
theSession.SetUndoMarkName(markId1, "Layer Settings")
theSession.DeleteUndoMark(markId1, Nothing)
End Sub
End Module
In the last script this is what makes it skip layer 2:
Continue For
End If
Do any of you have a suggestion for how I could add something similar to the first script?
(I don't really understand what the "tag"-stuff is about, maybe someone could shine some light on that as well?) Thank you!
I'm currently on NX6, but moving to 8.5 soon, if that matters.
BR
Stian LA
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
' Continue For
'End If
Dim csys_tag As Tag
Dim daxes As Tag()
Next
Next
End If
Next
End Sub
End Module
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module ChangeDatums
Sub Main()
'move sketches
Continue For
End If
Continue For
End If
i += 1
Next
End Sub
End Module
Continue For
End If
BR
Stian LA
RE: NX Journal - Move CSYS to layer, but skip CSYS on layer 2
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.Features Module Module2 Sub Main() Dim theSession As Session = Session.GetSession() Dim workPart As Part = theSession.Parts.Work Const newLayer As Integer = 41 Const skipLayer As Integer = 2 For Each myFeature As Feature In workPart.Features.GetFeatures() If TypeOf (myFeature) Is DatumCsys Then 'uncomment following If block to skip internal features 'If myFeature.IsInternal Then ' Continue For 'End If Dim DBuilder As DatumCsysBuilder DBuilder = workPart.Features.CreateDatumCsysBuilder(myFeature) Dim DCObj() As NXObject = DBuilder.GetCommittedObjects For Each temp As DisplayableObject In DCObj If temp.Layer = skipLayer Then 'terminate the for loop Exit For End If temp.Layer = newLayer temp.RedisplayObject() Next DBuilder.Destroy() Dim updateMark As Session.UndoMarkId updateMark = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "update") Try theSession.UpdateManager.LogForUpdate(myFeature) theSession.UpdateManager.DoUpdate(updateMark) Catch ex As Exception End Try End If Next End Sub End Modulewww.nxjournaling.com
What is an internal feature? How is relative to the part navigator tree?
Thank you.
I've just tested the script and I get this error message:
Line 42: 'LogForUpdate' is not a member of 'NXopen.Update'
Do you know how to fix this?
BR
Stian LA
Hasten the move the NX 8.5
For NX 6, you could try commenting out that line; I don't have NX 6 installed to test with, so I can't guarantee that that will fix the problem and everything will run fine...
For an example of an internal feature, start the "extrude" command. In the "select curve" prompt, hit the sketch icon and create a sketch. Finish the sketch and enter values for the extrude. When you press OK, the extrude is created, but the sketch does not show up in the part navigator, even though it is a full fledged feature. The sketch has been made "internal" to the extrude feature.
