NX Open - Get immidiate children
Hello all,
I'm taking my first steps into NX Open using c# and have the following problem...
From an assembly I am able to produce a list of the child components...However it is returning a list of ALL the components in the Assembly.
I would like to see only the immidiate children (sub assemblies toplevels)...
What Ihave so far is;
CODE --> C#
//get all parts in session and create List
                List<NXOpen.Part> newDisplayParts = new List<NXOpen.Part>();
                foreach (NXOpen.Part part in theSession.Parts)
                    NXOpen.Assemblies.Component childComp = part.ComponentAssembly.RootComponent;
                    if (childComp != null)
                        foreach (NXOpen.Assemblies.Component comp in childComp.GetChildren())
                            //Checking if comp.protype is an actual NXOpen part is
                            if (comp.Prototype is NXOpen.Part)
                                theSession.ListingWindow.Open();
                                theSession.ListingWindow.WriteLine(comp.DisplayName);
                                NXOpen.Part prototype = (NXOpen.Part) comp.Prototype;
                                if (prototype == workPart)
                                    newDisplayParts.Add(part);
How to proceed?
Ronald van den Broek
Application Specialist
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP EliteBook 8570W Intel(R) Core(TM) I7-3740QM CPU @ 2.70GHz, 16Gb Win7 64B
RE: NX Open - Get immidiate children
Don't loop through all the parts that are in the current NX session, only process the desired assembly part. In other words, eliminate this loop:
CODE
Instead, get a reference to the assembly of interest and only process that one "part".
www.nxjournaling.com
Thanks Cowski...It works now..
NX8.5.3 / TC9.1.2
