FEM CBEAM load extraction
Dear all,
I have a hybrid bolted joint with CBEAM fastener idealization. The aim is to extract fastener bearing loads as well as flows.
What is the procedure?
Are there any tools which can automate this process?
Thank you in advance
RE: FEM CBEAM load extraction
For example plane 1 is in the beam axis X and orientation vector Y (XY) plane, plane 2 is the normal to plane 1 (XZ). You could model the beam element and connect the end to the hole edge with RBE3 elements. I think it should give you what you need for bearing and axial.
If you want to learn a little more check this out:
http://www.stressebook.com/beam-and-bar-elements/
http://www.stressebook.com/beam-bar-elements-shear...
http://www.stressebook.com/rbe2-vs-rbe3/
www.stressebook.com
Stressing Stresslessly!
Much Appreciated
www.stressebook.com
www.stressebook.com
www.stressebook.com
