Excel question
Excel question
Hello -
I am importing a temperature program into excel. Imported will be set point (SP), temp internal (TI), temp external (TE), and time. I want to set up a template that will recognize when then TE settles out (i.e. 40 ± 0.1) and then record the temp from another row. Looking at the attachment, recognize A, and then record B. Does anyone know the equations that I should be looking into? Thank you.
RE: Excel question
RE: Excel question
RE: Excel question
For a second? A minute? An hour? Forever? For all subsequent recorded data?
RE: Excel question
RE: Excel question
CODE -->
Sub TE() Dim iRow As Integer Dim iCol As Integer Dim target, range iRow = 5 ' Starting Row of Data iCol = 6 ' Column containing TE data target = 40 range = 0.1 Do Until IsEmpty(Sheet1.Cells(iRow, iCol)) If Sheet1.Cells(iRow, iCol) = target And _ Sheet1.Cells(iRow + 1, iCol) >= target - range And _ Sheet1.Cells(iRow + 1, iCol) <= target + range And _ Sheet1.Cells(iRow + 2, iCol) >= target - range And _ Sheet1.Cells(iRow + 2, iCol) <= target + range And _ Sheet1.Cells(iRow + 3, iCol) >= target - range And _ Sheet1.Cells(iRow + 3, iCol) <= target + range Then t = Sheet1.Cells(iRow, iCol - 3) With ActiveSheet iRow = .Cells(.Rows.Count, iCol).End(xlUp).Row ' This skips to the end of the data End With End If iRow = iRow + 1 Loop Cells(1, 1) = t ' Put the found time in Cell A1 (note: Cells(Row, Col) for cell B5 change to Cells(5,2) End SubRE: Excel question
RE: Excel question
So for cells below, in column E you could have expression in cell E5 something like
=AND(D5=40,ABS(D6-40)<0.1,ABS(D7-40)<0.1,SUM($E$4:E4)=0)*C5
The answer is found by summing all column E or looking for max in column E.
C D E F G H
4
5 187.75 39.99 0.00
6 187.83 39.99 0.00
7 187.92 39.99 0.00 Answer 188.17
8 188.00 39.99 0.00
9 188.08 39.99 0.00
10 188.17 40.00 188.17
11 188.25 39.99 0.00
12 188.33 40.00 0.00
13 188.42 40.00 0.00
14 188.50 40.00 0.00
15 188.58 39.99 0.00
16 188.67 40.00 0.00
17 188.75 40.00 0.00
RE: Excel question
