Induction bends ASME B16.49 : Qualification bend tests and their significance
I have a problem regarding induction bends.
A contractor ordered and installed 20" induction bends without going through the the process of making and testing the qualification bends as required per B16.49 and our specs.
The actual bends were put into service without any NDE and the final pipe spool was hydrotested and put into service - until our QA/QC noticed it.
The party mow clims the hydrotest itself is a good inidcation of the quality of the bends since no destrictive tets can be performed at best they offer to do a DP or MPT on the in service bends.
B16.49 mandates the fabricating and destructive testing of the qualification bends I am not convinced that the contractor's proposal should be accepted.
I am not sure what else can be done in this cae.
Appreciate any help here.
RE: Induction bends ASME B16.49 : Qualification bend tests and their significance
In these types of situations, I would go back and attempt to qualify after the fact using the same bending method and material. If the results show acceptable bends this would be your final disposition. On the other hand, if the bends are unacceptable because of thickness or microstructure using the same method and material above, I would replace the bends.
