Stainless Steel Finish - Clean Rooms
Does stainless steel typically require a polished finish in a pharmaceutical clean room?
Say: ALL STAINLESS STEEL SHALL HAVE A NO. 4 STANDARD POLISH FINISH (APPROXIMATELY 150/180 GRIT).
RE: Stainless Steel Finish - Clean Rooms
A fine brush finish is common, but you need to know the spec.
Based on my research a No.4 Satin finish is generally adequate.
