UV Transmitting, Machinable material
I'm looking for a readily available UV transmitting, machinable material. Any suggestions? I have an application where I need to locate a component and then UV cure an adhesive, however the most robust way to location the component requires obscuring the glue joint completely.
RE: UV Transmitting, Machinable material
thread334-137505: UV or IR transparent polymer
