how to imhide components in a drawing
I have serveral components (bolts)became invisible on a drawing,but they visible
on a modeling app of a drawing.
How can I unhide those bolts?
Please advise
Please advise
RE: how to imhide components in a drawing
If that does not work, it may be that entire layers are hidden in the view: Format -> layer visible in view...
www.nxjournaling.com
stills can't see bolts in sections which I cut thru Top view
If the bolt is in part of the view that is cut away, then you won't see it.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I'll try.
How can I edit view style to enable background?
View Dependent Edit, select the view, then press Delete All Edits is working for me.
