Meshing difficulty
Meshing difficulty
Hi All,
I have a simple flat plate that needs to be analysed with transient heating.
It has a uniform thickness.
I understand that hex mesh would create a nice and easy meshing.
However, I tried experimenting it with a tetrahedral mesh. After meshing it with tet mesh, i sliced the geometry across to see how the meshes were aligned at this rear side. I realise that the meshes were very inconsistent. This is an example.
How can I go about fixing this issue? Or is this normal and should not affect result outcome?
Thanks.
Chinny
Thanks.
Chinny
RE: Meshing difficulty
I am using FEMAP.
and this is the correct file
Why are you using a solid mesh on a plate like that? Can you use 2D shell elements?
You may be able to increase the number of layers and get results on the other side.
www.stressebook.com
Stressing Stresslessly!
