Cracks on Lean Concrete - Do these need to be repaired?
Dear Guys. I would appreciate your help with my next issue.
Just now I am working in a Project of a power plant. We already completed the backfilling and poured lean concrete. After three weeks we have seen some cracks on lean concrete of a main foundation. The lean concrete's thickness is 100 mm. and 10 MPa.
The engineering says that these cracks need to be repaired. Many people told me that lean concrete is just to have a clean Surface and start to mark and install rebars and embedded ítems. I consider these cracks are a minor point and should not carry out reparation.
However, my engineering insist (without any code or reference) about this point.
Do you (guys) know about any code, standard, reference or technical background about cracks on lean concrete and if these really need to be repaired?
I would appreciate your help!
RE: Cracks on Lean Concrete - Do these need to be repaired?
By the way, my engineering also noted me some parts of lean concrete (blind concrete) shows some breaks.
I would appareciate your comments!
In both situations, you will have better luck finding a reference on training polka-dotted elephants the cha-cha.... then you will finding a reference to cite for when you have to repair this.
Does the engineering division freak out when they find a crack in the soil subgrade?.... Do they call HILTI to come look at it and sell them something???? I assume by power plant.. you meant nuclear power plant. (btw don't answer that question yes, putting photos on the net is a no-no) That industry allows people to be nth-level bureaucratic idiots. they can't see the forest for the trees.
I just wanted to have some technical opinión regarding this issue (new for me) because in my previous experience I have seen many cracks and a poor quality of lean concrete and no one ever said something for rejection.
I am wondering if you (guys) have seen something similar in other projects without future problems.
