Laser sutter for small 6 axis robot
Would it be feasible to mount a laser cutter on the end of a 6-axis robot capable of cutting metal foil?
Foil is aluminium and stainless steel layered together . total thickness <0.5mm.
Robot is an IRB120 with 3 Kg load carrying capacity.
Please recommend manufacturers that may have solution.
Many thanks
RE: Laser sutter for small 6 axis robot
I would think a fiber laser be perfect for that. You would have to make sure you don't exceed cable bend limitations though. Then use robotic arms for laser welding at pretty much every auto manufacturer. IPG Photonics (NH) makes them. Maybe unitek miyachi or Synrad. Only Integrator I know in my area (Nashua, NH) is Laser Advantage. they may even have some used systems if cost is an issue. Oh, in Arizona you have Jeff Grainger at Laser Electronics LLC, real smart guy, deals mainly with JK 700 series Nd/Yag Lasers which may be overkill. If looking Used, any 100 watt or more sealed beam CO2 should work. Coherent K series or Synrads you may be able to find.
"I am stuck on Band-Aid brand, 'cause they are stuck on me"
thanks RPosty.
I'm transferring thread to Mechanical Engineering for greater exposure and revised enquiry.
There is a robotics foum but its not very active- you can crosslink your mechanical engineering post to one in robotics.
http://www.eng-tips.com/threadminder.cfm?pid=1529
Use translation assistance for Engineers forum
Note the rules include No Student posting
