[Ask] Defining DOF in Stiffness Matrix
I got problem in hand calculation about defining unknown DOF at beam-column joint. Beam-column joint has to behave as simple connection. As I know for rigid, there are 6 unknown DOF for one member frame. How about simple connection?
Thank you.
Thank you.
RE: [Ask] Defining DOF in Stiffness Matrix
Hope this my be helpful.
1) X translation of the joint (shared between beam and column)
2) Y translation of the joint (also shared)
3) Z translation of the joint (also share)
4) strong axis rotation of the beam at that joint (not shared)
5) weak axis rotation of the beam at that joint (not shared)
6) torsion of the beam (may or may not be shared, I'll assume it's shared)
two rotational degrees of freedom for the column at the joint that are not shared.
Total of 8 degrees of freedom at that one location.
I think you should to learn how to form a stiffness matrix in local points of structures and of course then exchange it to global coordinates.
To forming local stiffness matrix you should characterize DOF in every local point. for this i will attach you a file that shows you DOF in different types of supports; Then the number of rows and columns in local stiffness matrix equals to DOF in that kind of support.
