Tolerances to apply before or after anodising?
Evening all,
Just a quick question on general opinion and concensus.
Generally, does one specify part tolerances as before or after surface treatments such as anodising? Clearly this is important as a tolerance in the range of a few to tens of microns, could potentially be well out of spec due to anodising?
What is the convention here, to specify tolerances having already taken account of film thicknesses, so that tolerances fall into where you really want them after treatment, or to specify tolerances as after anodising (and leave it up to the shop, which isn't in my opinion an ideal way of doing such things)
RE: Tolerances to apply before or after anodising?
"Where a part is to be plated or coated, the drawing or referenced document shall specify whether the dimensions apply before or after plating. Typical examples of notes are the following:
(a)"DIMENSIONAL LIMITS APPLY AFTER PLATING."
(b)"DIMENSIONAL LIMITS APPLY BEFORE PLATING."
(For processes other than plating, substitute the appropriate term.)"
If you specify "after plating" then you are turning design control of the size of the before plated piece over to someone else. Possibly the machinist on the shop floor. With a calculator if you're lucky. By his gut feel if you're not.
If you specify "before plating" then you have nothing to inspect the finished part to.
If it's really critical then the best way may be to make two drawings. As-machined and as-plated.
Alternately, it might be possible to add a note to the effect of "subtract something from all nominal dimensions to establish as-machined dimensions".
_________________________________________
NX8.0, Solidworks 2014, AutoCAD, Enovia V5
Additionally, engineering drawing generally defines acceptable finished part taking into account functionality of that finished part - so 'DIMENSION APPLY AFTER PLATING' usually makes more sense.
However, for tightly toleranced parts where plating thickness is significant in relation to total tolerances then more thought may be required.
How this is done may depend on how tightly integrated you are with your supply chain - i.e. internal shop, external 'partner' shop, external 'random lowest bidder' shop...
For the former case, I'd probably rely on manufacturing eng/machine shop supervisor/senior machinist or whoever to come up with a routing or 'production plan' or similar 'pre treatment' drawing.
For the latter case, maybe 2 separate drawings but then you leave yourself open if failed parts come in. You're inspecting to the plated part drawing, they machined to the unplated drawing. If there is a discrepancy it's harder to tell the problem - could be bad unplated drawing, bad machining, bad plating and may not be easy to tell which.
Some platings give nice uniform coatings, some can vary quite significantly based on part geometry and other factors - for these trying to simply add or subtract nominal plating thickness may be easier said than done.
Most of the time I'm guessing the 2 things you care about are the finished part dimensions, and the plating thickness. The pre plating part dimensions are effectively secondary to function so while I'd never say never, most of the time I'd rather not get involved in it.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Dimensions apply after plating for inorganic coatings.
Dimensions apply before plating for organic coatings.
Anodize, cadmium, nickel, zinc, black oxide -- all apply after plating.
Paint, ink, powder coat -- all apply before plating.
--Scott
www.wertel.pro
Tunalover
You're right. I've never been concerned with tolerances that small. What kind of business are you in that requires tolerances that tight?
Tunalover
@tunalover: I bet your suppliers make the painted parts to final dimensions, and the paint adds extra. No one is going to bother subtracting any allowance for paint if they're given certain dimensions. The practical tolerance on a painted part is likely such that they don't have to, anyways.
Short answer for me - if I don't control the pre-condition and final-condition, it leaves a gaping liability.
This is absolutely impractical to the point of impossibility, but for illustrative purposes, let's say you give "all dimensions apply after plating/painting" on a print. Now let's say make 1/2"dia holes oversized to 1"dia and lay a 1/4" of paint all around the inside of that hole. Not a good day. If your paint specs call out a min/max deposition, then you're covered, but if you simply say "applies after paint" and that's all - it is yet undefined.
If you spec the thickness of a coating/growth during final processes, and then a dimension after that process, then you've already fully defined and toleranced the process, even if the supplier has to do some math.
The fabricators do do the math I AM TOLD. Parts have been sent back for those that didn't for painted parts. Of course I am relying on the word of the front office representatives (who are of a sales variety). Somebody must be doing it right because the orders sent back have been few.
Tunalover
Plated or anodized screw threads are a common situation where some allowance during machining must be made for the coating thickness. However, precision (ie. UN class 3) screw threads are typically inspected with standardized snap gages or go/no-go gages that are sized for validating the final thread condition. FED-STD-H28 describe a standardized inspection method for UN screw threads. Attached is section 5.4 that covers the issue of inspecting coated UN threads. It basically states that when you call out a UN thread on your drawing the final thread condition must conform to the standard, which means after plating. But there is no limitation on any in=process inspection you might choose to employ.
In short, engineering drawings should define the condition of the specific part as delivered. You should think of a drawing as a set of requirements for the finished part, and not as a set of manufacturing instructions. Your drawing should describe to manufacturing minimum standards the finished part must conform to, rather than trying to tell manufacturing how to do their job.
You are preaching to the choir.
Tunalover
What I stated was that drawing dimensions don't apply either before or immediately after plating, but always apply to the final condition of the part. As I said, there are situations where the plated surface may be finish ground which would alter its dimension after plating.
However, your comment about painted surfaces presents a unique situation. Typically, close tolerance features are never painted. The thickness of a primer and topcoat can easily be .005" or more. It is also common to make a separate drawing that describes just the application of primer and paint, including masking of specific surfaces. There is a machined part or sub-assy which is called out on a finish drawing that describes the painting required. These finish drawings can get quite complicated for some components. I have made finish drawings for gearbox housings that were several sheets with detailed dimensions for masking surfaces like fastener spotfaces, sealing faces, threaded holes, studs, dowel pins, and electrical bonding surfaces. The masking of these housings would get so complicated we would have special plugs, caps and shapes of masking tape made to speed up the process.
On the 'engineering drawing' front, I agree with the statement that you should not make a drawing that infers the manufacturing method. I do believe there are exceptional circumstances that are not horribly uncommon, where an engineer would be wise to provide an "in process" requirement. Giving a bit of control over the manufacturing, when done WISELY, can shore up the supply chain and reduce do-overs. In a perfect world, you'll never source parts from someone who hasn't made parts like yours before, or isn't trying a new manufacturing method or process. The example of the chrome plated and finish-ground bearing race, as an example, would almost assuredly be ground after plating. That doesn't mean some bold manufacturer isn't going to try and eliminate that grinding step and see if he can "get away with" as-plated surfaces. When some "bold" manufacturer does this, you have a supply chain issue while you await their inevitable late shipment due to a failed 'experiment'.
You shouldn't have to do that. /Shouldn't/.
