Sync Manager
Sync Manager
I have a proble with a single channel machine in NX, the cynematics and postprocessor are done by DMG.
The problem is when I try to simulate a turning operation, the tool is not standing in the required positin (B-axis will not index itself in the simulation).
I have Looked trough some help wideos, some tips from the Siemens website and trough samples in NX.
The only answer I could find is that I have to sync the toolpath in order to index B-axis. This has to be done regardless of the machine beeing one channel or multiple channels.
The problem is that I cannot start the sync manager. The error is quite clear about that "Failed to initialize synchronization manager. Initialization error"
Is there any solution as to how I can start the sync manager or is there another way to have a propper simulation ?
Thank you,
Thank you,
RE: Sync Manager
Mark Rief
NX CAM Customer Success
Siemens PLM Software
