Smooth uniform blend between two surfaces with a step between them
Hi Guys,
Firstly i would like to thank everyone who uses this forum as i have gained so much valuable knowledge from posts and i visit the forum myself every day.
Im having trouble blending two aerofoil faces smoothly and uniformly between two tolerance bands which has a step between them. The first face has been offset from an area of a blade aerofoil. The second face which represents another area of the aerofoil has been offset but this time by a smaller amount due to tolerancing. Where these two faces used to meet nominally there is now an obvious step between them due to the offset.
Is there a way i can get NX to uniformly and smoothly blend the two faces of the offset aerofoil?
RE: Smooth uniform blend between two surfaces with a step between them
Without at least a picture of your model (having the model itself would be much better) there's not much that anyone could say about this.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I think we'll need to see this from a few more viewpoints.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Quote (CJRT)
...uniformly and smoothly blend...
I think it really depends on what you mean by this. If this is a single solid body, you could just use 2 edge blends to get an "S" shaped transition. All surfaces would be tangent; but, I'm not sure you would consider that "uniform and smooth".
www.nxjournaling.com
Cowski and Robert are pointing you in the right direction with the information provided. You need to expand a bit more and let us know the continuity requirements if the above responses aren't what you're expecting.
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
